Speaking of tires
Oldskuul
I just changed over to metzler since all the talk of avons having issues.
My first impressions are that the avons that I replaced rode and handled a hell of a lot better, the rear actually feels like I'm getting read squirm at higher speeds.
While performing some stunt riding (observing the rear tire while driving down the road) I noticed quite a bit of run out on the rite itself.
I measured the rim with a caliper and then the tire itself... 200 thou plus of runout on the tire.
Time to check if it seated or is defective.
Sent from my I897 using Tapatalk
I've only put a couple hundred miles on my Metzler, so far I can't tell any difference. The ride and handling seem to be the same. But like I said only a couple hundred miles. I haven't ridden in the rain yet, but so far its been good.
Oldskuul
I let out all the air and pushed it up and down the driveway a few times and reinflated, runs a lot better now.
Well see how it stacks up in the next few thousand Miles:)
I've seen wear marks on the sides of your tires too Jan :D We call them "Chicken Strips" Who ever has the smallest wins :D
Abaco21
Well I am offering myself up as a crash test dummy for the cobras. In 2000 miles I've carved my front tire into a "V". I'm over Metzeler ME880's after wearing them out on my RF and Warrior. Plus they don't make a 250. I dont like the look of the dunlaps. I use a lot of front brake trailing into turns rather deep, so fronts tell me more than rears. I'll put one on the front in the week to come, and report once I get a read. This whole cracking/separating thing is just weird. Isolated? Or will I get bit by a Cobra?
Steve
I've only seen the tread separating problem on the 300mm tires. That last 2 Cobras I purchased only lasted 2500 miles on the first one and 1200 miles on the second one before the tread started separating. I don't think the Metzler can do any worse. We'll see how it goes.
Abaco21
Well then I won't be much help. But I thought that at least one or two of those pics showing cracks in the sidewall were fronts. I'm hitting the sack now, but I'll re-look in the morning.
S.
Bowhunter
Steve,
My buddy(Postman) has had two of the Avon front tires split all the way around the
rim. They were properly inflated and ridden with a single rider. Here is a couple of
pics of the first ride on the NEW Avon Cobra last spring. Keep a eye on the side-wall
of the tires so that you don't become a crash dummy!
BadBrad
2005 Pitbull
I'm with Alan on this. I got great milage and performance from Avon until recently. The last Avon Venom 300 lasted about 2000 miles, then the center of the tire began to wear like I was doing burnouts every day. The rubber was very soft and Avon won't stand behind something like that because they can't prove it wasn't from me riding too hard. I ride like most, but don't burn the tires. I went with Metzler and other than virtually no clearance between the tire and beltdrive, no issues so far. Rides good.
