Iman Well-Known Member Apr 29, 2010 #1 I need to purchase new spark plug wires and was wondering what make and part # is best for our dogs.
mobsta Well-Known Member Apr 29, 2010 #2 taylor wires and rev tech,some say taylors are better i have used both,j/p cycles etc.
Mickeetwo Guru Apr 29, 2010 #3 I'm using the Taylor wires with no problems. Mine are 13" , but 11" would work also.
Iman Well-Known Member Apr 29, 2010 #4 I'm running dual coils. Does taylor make anything smaller?? I'm looking for around 5" or 6"
mobsta Well-Known Member Apr 29, 2010 #5 they come universal,cut to fit,the spark plug end is attached,you cut and install the coil end
Mickeetwo Guru Apr 29, 2010 #6 The wires I bought came with the boots already on both ends. They were ready to go on when I removed them from the box.
Iman Well-Known Member Apr 29, 2010 #7 it looks like they come in 24" for the 90 degree. I will have to cut. Thanks for your input!!!
Iman Well-Known Member Apr 29, 2010 #8 I see that Taylor makes 2 kinds of wires. The 8mm spiro and the 8.2 thunderbolt. Which ones are you guys running?? Thanks
