billyberoux
Any trouble shooting ideas for a solenoid that won't engage when you hit the start button? i've done the following:
1)tightened/cleaned battery terminal connections and checked battery for full charge
2) removed solenoid cover , cleaned copper ring and contacts.
3) manually engaged solenoid and no problem starting
3) checked for power going to the solenoid by touching contact on top of solenoid w/ screw driver to metal and getting a spark
When I put the solenid cover back on and tried starting it with key on and run/start button the solenoid still won't engage.
