jimizee028
TRUE COLORS COLLISION
so everyday the norm is wake up brush the teeth hook up a diet coke sit in front of the computer and go to big dog biker site...i read all the posts about everything,so last week in gettysburg notice bike is walking when I pull in clutch lever... still also cant get neutral real easy,go about adjusting clutch... would be ok for a little while then i would either have slippage or bike would start walkin again,course at this time i am totally paranoid cause sturgis is in 2 weeks and life is pretty good so i am worried to death after seeing and hearing about the catastrophic failures comin from some of your guys clutch assemblies and all the same symtoms are present in my case,well today i drop the outer primary open it all up and i literally can wiggle my entire clutch basket and hub assembly back and forth side to side at least 1/2 inch...i am flippin thinkin auto matically the basket has snapped like the pictures on the posts from you guys,i dissassemble entire clutch assembly and it is not destroyed put it all back together and tighten everything down LIKE ITS SUPPOSSED TO BE and to my surprise i have no wiggle no play just a tight ass assembly that looks like no problems,put it all back together readjust clutch cause now it is way too tight,put primary fluid in take it for a spin and everything seems ok............my guess is the hub assembly bolt loosened up and the entire cluth basket was loose,,,,could this be the start of why all these clutch assemblies are blowin up??????has this happened to anyone else???well gone down under to have shrimp on the barbie..................
:bang: :choppersmiley: ....
