headshothills
Yes, Im definitely interested in how you placed/mounted the caliper ones, all the other spots seem like the goto no brainer spots, the caliper/fender ones seem to be where I would question exactly where/how the most.. Looking forward to those pics!!I placed led's under the tank, one under the coil/ignition cover, two (one above, one below) on the back of the carb backing plate that the air filter cover screws to, one under the battery box (shines down on top of the starter and engine), two strips, one each side, under the engine. I ran the strips along the top, inside of the frame on each side and they provide a lot of ground light. I placed leds on the inside of each brake caliper, these reflect nicely of the rims, and I added a strip on the inside of the belt guide, which also provides alot of light on the right side of the rear rim.
When I get home, I'll post pics.
Now that looks great!!I like to keep it simple and put a couple under the tank and 1 around the oil tank
Again... Great pics...
you guys would have stole the LED show with those, most of the LED installs I saw, were just mehhhh.. Either you saw the LEDs and each individual LED rounded light, which to me makes it look like a Xmas tree IMO, I dont want to see the lights or the reflection of each and every LED light on the strip, I want to see the LED glow, without seeing the physical light strip... if that makes any sense...
