mcgroom
Got word on this a few weeks ago but looks like they got it done. Haven't seen any posts on here about it so I thought I would throw it out as information.
Superior S&S® Lubrication For Your American V-Twin
Proven Performance® Protection
S&S Cycle is pleased to introduce a new line of premium drive train lubricants to keep your American v-twin motorcycle running like new for years to come. S&S has long been known for building the biggest, baddest engines on the salt, strip and street, so it only makes sense that the same company that provides the parts should offer a way to protect them from the rigors of high performance riding. Make no mistake, though, you don’t have to be a racer to benefit from world-class S&S lubrication. Whether your rides last a quarter mile or cover a continent, S&S engine, transmission, and primary oils provide the best protection available. S&S lubricants are manufactured exclusively for S&S by Spectro® Oils of Brookfield, CT and are the best choice for stock Harley-Davidson® and S&S high performance engines.
Complete drive train protection!
Why should I pay the extra money for synthetic motor oil?
It’s a matter of “Pay me now, or pay me later.” Synthetic motor oil reduces wear and makes your engine last longer because it does a better job of lubricating moving engine parts. Since it also stands up better to mechanical shearing and high temperatures, it maintains its lubricating properties much longer. To put it simply, synthetic oil lubricates better right from the getgo, and it keeps on protecting your engine from the time you pour it in to the next oil change.
Who actually manufactures these lubricants?
These products are manufactured exclusively for S&S Cycle by Spectro® Oils of Brookfield, CT, USA
Can I run multi-viscosity motor oil in my shovel?
Yes! And not just shovels. S&S multiviscosity motor oil can be used in any engine regardless if it has iron cylinders.
Isn’t 20w50 thinner than SAE50?
The answer is yes, but not really. When it’s cold, 20w50 is thinner and flows better than SAE50 at the same temperature. If your engine could talk, it would thank for using 20W50 instead of SAE50 every time you start it cold. Multi-viscosity oil flows much better at lower temperatures, so your engine will get lubrication much quicker than it would with an equivalent single weight oil. The important thing to remember is that most of the time your engine is running, it’s hot, and 20w50 has the same viscosity as SAE50 at operating temperature.
I’ve heard that synthetic motor oil is too slippery for the roller bearings in my lower end?
Hogwash!
Protect your engine with S&S Engine Lubricants
Oil is the life-blood of your engine, so give it a transfusion of U.S. made S&S engine oil. S&S engine oils are specifically designed for air-cooled v-twin engines such as S&S® Cycle, Harley-Davidson, and other American v-twins. S&S offers a number of grades and formulations to fit your application and your budget. All S&S lubricants exceed S&S Cycle and Harley-Davidson warranty requirements so it’s hard to go wrong. So pick up a twelve-pack of “long necks” and give your engine and drive train the protection it deserves. Don’t settle for less.
S&S Premium Synthetic Engine Oil
S&S Premium Synthetic engine oil gives your v-twin engine the ultimate in protection. Premium synthetic base stock coupled with the exclusive S&S additive package offers superior lubrication for reduced engine wear and lower oil temperatures. S&S Premium Synthetic engine oil provides consistent viscosity, and resists thermal breakdown and oxidation at elevated temperatures. Exclusive formulation provides the enhanced oxidation protection needed when running ethanol fuels. The best choice for any engine, but a must for performance engines and for engines operated in demanding conditions. Available in cases of 12 one-quart bottles and in convenient S&S oil change kits with 4 quarts of oil and a premium oil filter.
S&S 20w50 Premium Synthetic Engine Oil
Case of 12 1-Qt bottles
Part Number 310-0285
S&S Heavy Duty Engine Oil
This petroleum based oil for air cooled v-twin engines contains superior petroleum stocks blended with advanced anti-wear additives for reduced wear and extended engine life. Anti-carbon additives eliminate a primary cause of valve sticking. This is a good choice for vintage and modern engines under normal driving conditions and for touring. Available in 20w50 and 25w60 grades. S&S Heavy Duty 25w60 is ideal for hot climates and big inch engines – any application where high temperature is an issue. Available in cases of 12 one-quart bottles and in convenient S&S oil change kits with 4 quarts of oil and a premium oil filter.
S&S 20w50 Heavy Duty Engine Oil
Part Number 310-0287
Protect your drive train with S&S Gear & Primary Oils
Transmissions and primary cases have very different lubrication needs from those of internal combustion engines. That’s why we made them a different color than the motor oil. S&S Transmission Oils are colored blue, and S&S Primary Fluid is colored red for easy identification.
S&S drive train lubricants are specifically formulated for the application to reduce wear, provide smoother operation across a wide temperature range, and reduce power losses from friction. These premium quality lubricants exceed Harley-Davidson® warranty requirements. Available in cases of 12 one-quart bottles.
S&S Premium Synthetic Transmission Oil
This full synthetic gear oil offers the best protection for Harley-Davidsion® big-twin transmissions. The combination of premium synthetic PAO (polyalphaolefin) base oils and an advanced additive package delivers unparalleled protection under high loads and stands up to extreme heat. S&S Premium Synthetic Gear Oil extends gear life, and reduces drag, friction losses, and wear. Not only will your transmission shift more easily and more smoothly, but it will last longer too. A.P.I. GL-1 rated.
S&S 75w140 Premium Synthetic Transmission Oil
Part Number 310-0292
S&S Heavy Duty Transmission Oil
This premium quality petroleum based hypoid gear lubricant is formulated specifically for Harley-Davidson® big-twin transmissions and is highly recommended for aftermarket v-twin gearboxes, as well. S&S Heavy Duty Gear Oil reduces drag, friction losses, wear, and extends gear life. In addition, it prevents rust, corrosion, oxidation, foaming, and gear pitting. A.P.I. GL-5 rated..
S&S 85w140 Heavy Duty Transmission Oil
Case of12 1-Qt bottles
Part Number 310-0291
S&S Extreme Duty Primary Oil
S&S Cycle’s new Extreme Duty Primary Oil is formulated specifically for use in primary chain cases of Harley-Davidson® big twin and Sportster® models. This is a petroleum-based lubricant with high shear stability and the ability to withstand extreme loads. Special polymer additives allow it to remain stable at elevated temperatures and provide exceptional clutch engagement. The SAE 85w viscosity provides low drag and frictional losses and eliminates clutch drag and slipping.S&S 85w Extreme Duty Primary Oil
Part Number 310-0290
S&S Quick Oil Change Kits
S&S® recommends that you change your oil and filter every 2500 miles or six months, whichever comes first. And to make it easy, we offer S&S Quick Oil Change kits. Everything you need in one convenient package.
S&S Quick Oil Change Kits for late model S&S and Harley-Davison® engines contain four quarts of either S&S Heavy Duty 20w50 Petroleum, or Premium Full Synthetic motor oil plus an S&S oil filter with chrome finish. They are available for 1984-‘99 Harley-Davidson® Evolution® Engines, 1986-’13 Sportster® and 1991-’02 Buell® models, and 1999-’13* Twin Cam 88®/96™/103™ and all S&S X-Wedge® engines.
S&S Quick Oil Change Kits for vintage bikes are available for 1958-’82 big twins and 1953-’78 K and Sportster models with in-tank oil filters. These kits feature a premium Perf-Form® HD-1 drop-in filter.
S&S Quick Oil Change Kits For Late Model S&S® And Harley-Davidson® V-TwinsS&S Motor Oil Grade1984-‘99 BT, 1986-’13 XL
and 1991-’02 Buell®1999-’13* BT
and all X-Wedge®*S&S 20w50 Premium Synthetic310-0297310-0298S&S 20w50 Heavy Duty310-0293310-0294*Contains an anti-drain back valve
S&S Quick Oil Change Kits For Vintage S&S® And Harley-Davidson® V-TwinsS&S Motor Oil Grade1958-’82 Big Twins and 1953-’78 K and
Sportster® Models With In-Tank Filters*S&S 20w50 Premium Synthetic310-0301S&S 20w50 Heavy Duty310-0299*Includes Perf-form® HD-1 drop in filter
S&S OIL FILTERSYear ApplicationMicron
RatingChromeBlackeach12 packeach12 pack1984-’99 BT, 1986-’13 XL and 1991-’02 Buell®30μ31-4102310-024031-4101310-02391999-’13* BT and all X-Wedge®10μ31-4104310-024231-4103310-0241* Contains an anti-drain back valve
PERF-FORM® OIL FILTERSYear ApplicationMicron
RatingEach1958-’82 BT with
in-tank oil filters/
1953 to 1978 K and
Sportster® models.10μ310-0284
- Engine, transmission, and primary lubricants
- Exceeds S&S® and Harley-Davidson® warranty requirements
- Enhanced levels of zinc and phosphorous for greater wear protection and longer engine life
- Protects against oxidation from moisture build up associated with ethanol fuels
- Smoother shifting and less transmission noise
- Safe for catalytic converters
- Petroleum or full synthetic
- No funnel needed
- Manufactured exclusively for S&S® by Spectro® Oils of Brookfield, CT, USA
1953 to 1978 K and
