Bike was running rough. Plugs were black, changed plugs runs good again. Buy the s&s dual induction air cleaner to maybe lean it out a little. When I install air cleaner, I adjust the air/fuel mixture screw just to see where I was at for jetting. Rear plug was clean with a little gray starting on 90 degree part of electro. Front plug looked good. Bike ran better than ever. Ijust dont want to burn up motor. Checked intake gasket and did a push rod adjustment as suggested on here. No change. Readjust air/fuel mixture screw so the front plug is black and rear plug looks good now. Bike does run ok no backfires, just making sure it ok to run like this for now. Do more troubleshooting this winter.
