RSD Actuator assembly
nine lives
We all know about the cable breakage problem and what causes it, at least some of us do. I'm going to find out if this Ultima has a different actuator that does not bind the cable and cause fatigue and failure of the cable.
This assembly is priced at $105.99, not a bad price if it fits.
Here is the discription: Sorry could not copy an image off my catalog disk.
ULTIMA® RSD HYDRAULIC CLUTCH COVER ASSEMBLY
Replacement cover for use on all Ultima right side drive transmissions
and most aftermarket right side drive transmissions. Includes 3 mounting
bolts.
★96-960 RSD Hydraulic clutch cover assembly
Note - when ordering replacement
cases: 6 speed RSD & 5 speed LSD
transmissions require cases with
machined in speedo hole.
