kpchief
I have had this issue since I got the 04 bulldog in april. The bike will idle fine when*it is first started up, it will accelerate and run just fine. After about 15 minutes into the ride it will have trouble idling. The lights on the tach will blink, only when it is idling, which is telling me low oil pressure. I have changed the oil and used a K&N 170 filter with Mobil1 20w 50 oil. I also cleaned the tappet screen when i changed the oil. I have cleaned the air filter with the K&N kit and re-oiled it. I have reset my carb to factory settings and adjusted it following the S&S guide. It will run fine but just has issues idling after it is warm, it will eventually die after idling rough for a minute or two. Any ideas on why it would be idling rough?*
I also have oil dripping from the crank case breather, behind the air filter. It sure makes a mess. Could this be part of the issue?
Sorry for the long post, and thanks for everything
