reloaderbmg
OLD DOG
Have a 07 k9, after brake in [3000 miles] changed to amsoil 20w50 for engine.
Noticed noise in top end, talked to dealers up north found others had same noises, thay had rebilt a lot of oil pumps before some one told them to drill out the head breather pipe/check valve [on rear head] plug the vacuum hose to the front head & run that hose to the breather backing plate.
seems with the vavuum removed from the front tappet area, the bike gains
thee psi. oil pressure on top end! [vacuum was sucking the oil out of the bearings]
have no oil drip at air filter or any problums, you still will have some noise in top end but thats just syn. oil, a small trade off for the good things it brings to the table :up: :2thumbs:
