Right front blinker doesn't work???Rear does.
I have an 03 BD chopper. The front right blinker does not light up or blink. Has anyone had an issue with this? I swapped out the lights with the other front and bulbs are good. Swapped out the ehc and checked connections..all good.
Any help???
Thanks again
DRBarnhart
Insert title here...
If the bulb is good and the EHC is good you have a broken wire. Check for continuity between pin 5 on P-1 (on the EHC) and pin 2 on the turn signal (red wire) to verify...
Dennis
