Bdogridgeback
Hey Guys
Is the wheel suppose to be free spinning when jacked up & clutch pulled in ?
I can't turn it in first gear but can in 6th and can feel the clutch engage when I let it out.
Is this normal ?
I just replaced the cable and followed the factory service manual with the rod lightly seating, half turn out and then adjusted the cable to take up the slack and locked the rod nut down , did this 3 times with the same result.
Thanks for the help.
Is this normal ?
Like Tapio said, if clutch is pulled in, tire should spin because the transmission is disengaged...may have slight resistance.
