Removing Cam Cover on k9
Doug G
Looking for some help on removing my cam cover on 07 k9, want to send it out for chrome. I removed the points cover and all the bolts on the cam cover. There is a stamp that says remove and an extra open threaded hole under the points cover, but I'm not sure where to go from there. There must be one more step unless the gasket has an incredible seal and I'm just not prying hard enough to remove the cover. Any suggestions would be great!
You mean like this?
You have to bolt a bar or something to it. Then pull hard. It will come off FAST when it does... The thread is the same as the cam cover bolts.
You'll see this
Doug G
Gas Man,
I'm new to this site and trying to figure it out, but I couldn't ask for a quicker or better response. The pictures are a big help, Thanks!
Yeah as Sul said... there is a puller for it. I just used a bracket that I had laying around.
