phoneman85
I run a 656V2 Red Shift cam in my bike. Mine is a EFI but below is what I have and what it does. It has a torque curve from hell and will do whatever I want to do.
Neil
http://www.bigdogbiker.com/forums/dyno-runs/14469-dyno-results-07-bulldog-w-thundermax-wide-band-efi.html
Because it is a EFI bike an they come with plain tappet rockers and a single wound .585 lift springs I had to address this no matter what I did compared to the good ole carbureted bikes and what they come with. The stock OEM EFI system is a S&S VFI Single band with a propriety map and all it wants to do is adjust to a EPA 14.7 AFR so it all had to go because I want to tune the bike and it learn on its own.
It still has the stock air box on it so I know if it suffering for air in too
S&S Roller Rockers
JIMS .675 Lift valve springs
Red Shift 656V2 Cam with some clearance work
Stock jugs cut 25 thousands
John Sachs did my head work and props go to him for his work and knowledge..:2thumbs:
He helped me out more than anyone will ever know. Do not hesitate to use him or believe in him
Heads were ported and polished and the springs set up for the cam.
John installed 2.02 and 1.615 valves and put in new valve guides
John set up the heads for a 11-1 compression after I told him how far the pistons were in the hole and milled the heads
I have a R&B Racing 2-1 pipe
I installed a Wide Band Thundermax EFI for all my tuning needs. Jason at the Thunderheart factory did the initial mapping for me and continues to help me and refine things. They did the original install or conversion of the wide band on my Big Dog to see what it would take after talking to them. It is a easy conversion for those with a EFI bike. I am using a two piece unit due to the space and the EHC bracket. A one piece unit will fit if you modify where the battery hold down rubber strap attaches at. I will do this sometime and eliminate the EHC as well.
This bike has a lot more in it and I need to do some tuning on it when I have time. For what it is worth and when I get someone to film for me to back it up, at 30 mph if you tach it up and turn it loose, it will start spinning the 300mm and pull the front tire off the ground....
Its a Big Dog...and sometimes a bad dog
Neil
I have been reading a bunch of dyno sheets lately on the forum so I decided to take mine down and do a pull. I drove it about 45 minutes to get there and the bike only cooled down about 15 minutes before they made the pulls. Anyway, the bike runs pretty good for a big ole sled.....
2007 Bulldog EFI W/Thundermax Wide Band
Made 128 HP and 141 TQ.....
Neil
