Rear wheel bearings.....
jimizee028
TRUE COLORS COLLISION
Am I supposed to put 2 bearings side by side in the larger rear wheel hub instead of the 1 wider original bearing????? I searched and searched and found this info no where...i have an 07 Chopper?????
Dual bearings allow for a back up if one goes bad.
Easier to press in and out
Run cooler
Cheaper
Just my opinion of course
jimizee028
Ok ...I see now...I thought it was just 1 wider one in there but it wasnt it was 2....Thanks
because of the pull of the belt, there is more pressure on the drive side bearing so if you have 2 on that side, better distributes the forces. (more pressure=more heat=faster destruction)
