I could live with the gap. Im more worried about mechanical issues when changing the set up.Your overall tire height will end up being 2" shorter it looks. A 280/40-18 is only 26.8" tall. So you'll have an inch more gap between tire and fender.
Yes, They said there is order of 100 coming just no time frame... Just want to see if this is going to continue to be a issue is it better to change the set up and be done with it.Have you called KMW.
That had a stock of the 280s recently
I'm thinking he needs to MOD the frame/tranny and go with a 360 hahaSince they are in business again, fingers crossed, probably not an issue in the immediate future.
As you well know a 280 is not a common tire.
If it were my ride I would be trying to come up with something more common.
Unfortunately I haven't done any work in that area so I don't have a solution to offer.
