BATMAN2696
When I was polishing the Dog I noticed I could move the tire when I pulled on the top and pushed on the bottom. I figured I had a bad bearing so I pulled it apart. I noticed when I was pulling it apart the entire bearing on the pulley side spun inside the hub. I was hoping the bearing was just worn but today after I had the bearings pressed out I checked one against the other and the hub is definitely worn. I can put the bearing in with slight hand pressure and easily pop it back out. Now I have to try and figure out where to get another hub. I am pretty sure the belt was too tight pulling on the rear wheel enought to wear out the hub. As I am new to the Big Dog scene any help in identifying who made the wheel, where I might find a hub, and since I'm at it, how do you identify which frame you have. Thanks
The hub is stamped on the brake side BDB-4 and on the drive side BDB-5
On this one you can see a ridge between the inner and outer bearing locations.
This is the wheel, if you can help identify the manufacture I would sure appreciate it.
