Rear brakes rubbing after bleeding
krkostecki
I finished bleeding my brakes and thought everything was good, but now the rear brakes are rubbing when I manually rotate the rear wheel. Prior to bleeding, the rear wheel rotated without rubbing. Is there a way to adjust the brakes slightly or did I do something wrong in the bleeding process? Brake works great, just rubbing when brake is not applied.
As always, thanks for the assistance. :2thumbs:
mcgroom
Did you have the caliper off or did you just bleed the caliper. If you had it off may have the shims in wrong.
