Phatnasty
Question....rear axle tightened to spec but spacers are not flush. Everything is flush on the belt side but I can turn the spacer with my fingers. (is this normal?) On the brake side...both spacers and caliper arm are not flush. I can wiggle them back and forth a little, maybe 2 or 3 sheets of paper width.
Common sense tells me everything should be snug. I would also think water would get into the wheel bearings if not flush. Am I correct?
This is the 2nd time I've changed tires and don't know if I just missed it the first time or what.
What do I do? Try to tighten it until they flush or leave it as is?
Thanks
Thanks
