HellOnWheels
Just curious, been looking all over the web and haven't been able to find an answer, but what is the rake angle of the Vintage Sport's front end?
Even the manual didn't mention it, warned against doing anything to change it thoughVintage Sport Vintage Sport
MANUFACTURER Big Dog Motorcycles Big Dog Motorcycles
MODEL YEAR 1999 1999
MODEL Vintage Sport Vintage Sport
M.S.R.P. $25,900.00 $25,900.00
Weight 645 lbs. 645 lbs.
Wheelbase 66.25 in. 66.25 in.
Seat Height 25 in. 25 in.
Engine 1750cc, Air cooled, 45 degree V-twin cam, OHV, 2 valves per cylinder 1750cc, Air cooled, 45 degree V-twin cam, OHV, 2 valves per cylinder
Displacement 107 cubic inches (1750 cc) 107 cubic inches (1750 cc)
Bore x Stroke 4.0 X 4.25 in. 4.0 X 4.25 in.
Compression Ratio 9.6:1 9.6:1
Fuel Tank Capacity 5.0 gal. 5.0 gal.
Transmission 5-speed, wet clutch 5-speed, wet clutch
Final Drive Belt Belt
Brakes Front: 11.5" rotor with 4-piston caliper
Rear: 11.5" rotor with 4-piston caliper Front: 11.5" rotor with 4-piston caliper
Tires Front: Avon AM20 130/90X16
Rear: Avon HL30 160/80X16 Front: Avon AM20 130/90X16
Suspension Front: Chrome 54 mm telescopic inverted
Rear: Gas charged shocks Front: Chrome 54 mm telescopic inverted
Found everything but the rake also.
Looks like a work!
They all have,or at least most of them have the 3 in the tree. I think what he was looking for was the neck rake.I think that 3 degrees over stock is correct.
Ahhh, I read it too quickly. My Vintage has, I believe, a Road King front end and has increased the rake from 26 degrees (stock HD) +3 to 29 degrees. I remember having this discussion with Mike at SW V twin some 15 year ago and this is what I recall. It is something close to that. Does that make sense? Maybe it was only 1-1/2 degrees more rake on the neck.They all have,or at least most of them have the 3 in the tree. I think what he was looking for was the neck rake.
