If there is a 'How-To' thread already on this, please post a link. (I did a search but couldn't find one).
I have beads in my tires and soon have to get new tires.
My questions are:
1. How do I (or the shop changing tires) collect all the beads? (do they settle in the bottom of the old tire or are they all over the place due to static electricity?) Do you have to vacuum them out with like a filter sock in the vacuum hose?)
2. Assuming you can collect them all, can you put them in the tire while changing, OR do you have to put them in through the stem as you did when you first got them (after the new tire is sealed to the rim) ?
3. Do you have to clean them in any way before re-use?
4. As an afterthought I should ask, Do the dyna beads wear out (from rolling around and colliding with each other)?
I would appreciate any info or experience from members who have re-used their beads and perhaps they could create a thread in the 'How-To' section on how they have done this.
Thanks in advance, Shovelcowboy
My questions are:
