Questions On Tribal Trees
mts301
Since the threads on the accutronix triple trees that I saw I am in dire need of getting a set :) Those things are killer !! So if I order the 41mm set with the stock 3 degree rake will these pretty much fall into place besides the turn signals?? I have an 06' pitbull. Trying to get all the info together before I order a set. All input is welcome :)
Thanks,
Matt
There is no straight answer. When I did mine and I believe I was the first guy on here to do so. I had to machine both fender spacers, wheel spacers, and fork brace & mounts.
However, the last guy that did a set had no problems.
The thing is that bdm's specs have a larger range of tolerances. So it depends on where you bike is in that range vs the relation to accutronix.
Posted via Mobile Device
mcgroom
As Gasman said, Bigbass had no problems with the trees we sold him.
Send him a PM and I am sure he will be more than happy to go over the install with you.
Keep us in mind if you decide to get a set. Should be able to help you out quite a bit.
Mick
