whatever01 Member Feb 22, 2009 #1 I noticed the other day that my push rod tube was moving a little as the bike was running. I checked it out and it seemed to be tight. Has anyone ever seen this and should I worry or do anything.
G Gas Man Cool isn't cheap Calendar Participant Feb 23, 2009 #2 Are you sure its tight? Remove it, clean the threads, add loctite and put it back on. Make sure its not the whole pulley cover that is tight.
Throttle Jockey Don't Look at my Member! Feb 23, 2009 #3 Gas Man said: Are you sure its tight? Remove it, clean the threads, add loctite and put it back on. Click to expand... The push rod tube??? TJ
G Gas Man Cool isn't cheap Calendar Participant Feb 23, 2009 #4 Oh shit... not enough coffee when I typed that... was thinking clutch rod cover... The push rod covers... those should snap into place. Check this thread to see some good pics http://www.bigdogbiker.com/forums/how/463-pushrod-adjustment-how-pics.html
