Pulling the gas tank
Tim
Founder
Lifetime Supporting Member
I removed the two allen head bolts... what else is holding the tank down??
I see an allen head plug on the right side of the tank, but I'm thinking this is a drain.
Set me straight guys.
Mine has four posts, one in each corner. On the new bikes I understand they are mounted with three posts. At the rear of the tank you should see some kind of rubber mounted bolt that should allow it's removal.
Tim
Founder
I just figured it out and will post pictures for anyone else in a bit.
Yeah just remove the bolts... don't forget to unhook the fuel line...and be carefull of the speedo
Tim
Founder
I didn't think I had to remove the second bracket.
