psi carb
malange
I understand there is some questions on the PSI carb. I put one on a month ago. Had it dynod. Have'nt had it out on the street yet, weather up here in Wisconsin has not worked well with me.
Here are some numbers from the dyno. After the PSI was installed.
9:24am, 46 degrees F, 45% Humidity Max power=100.13, Max Torque=113.30
Power up +10 and Torque up +5.
The throttle response is unbelievable..
As soon as the weather brakes I will get her out on the road and let you guy's know more.
malange
Had the dealer do the install. Dynoed before the install. Pic's soon to come. Just got her back need to clean. I did put the 3' velocity stack on from Thunder Cycles. Looks great...
