Easyrider
I've been on a tear reviving my 1997 Proglide that's sadly spent too much time sitting around in the garage for a long time. I purchased it new so no one has ever put a wrench on it other than me. This bike has been a fun, attention getting bar hopper for a long time. The issue I am asking about could have a lot to do with my old age and the ravages of riding a rigid frame panhead and dirt bikes in my younger years. But the Big Dog's ride is REALLY stiff so I feel I need to look into it some.
I recently went over a small pothole and it bottomed out HARD. Loud clunk. This bike is not a low rider so I don't know what hit what but I decided I needed to take a deep dive into the state of the rear shocks. I contacted Progressive and their "expert" seems to know less about their shocks than I do. And I don't know jack.
What I do know is that what's on there is a 412 series Progressive Suspension shock set. They look to be exactly the same as what's listed in my HD parts list for a 1997 FXR/FXWG. The adjustment ring is on the bottom of the shock and uses a 5 position cam scheme. I do not currently have an adjustment tool for them but will order one soon.
The HD service manual strongly cautions to NOT adjust the shocks from max to minimum settings as this can cause serious problems and damage something... something to do with the swing arm as I recall. This makes no sense to me. Perhaps someone a lot smarter than me on here can fill me in? You should be able to adjust back and forth to all five cam settings indiscriminately right? So long as both shocks are adjusted to the same setting of course.
When I get on the bike, the spring compresses an inch or two. If I jump up and down the rear end bounces slightly but it's VERY stiff. I weigh 220# so not a little guy. There's really no way to test the dampener. My experience with shocks is that when the dampener goes bad the rod just slides up and down offering no resistance. If there is a problem with the dampener in my case, it's that one or both of the rods are frozen in place. The Progressive "expert" offered zero help on figuring out if these shocks are bad/worn out.
I thought I'd start by adjusting the shocks to their minimum preload and getting a baseline on how it rides at that setting. Perhaps someone here knows but I'm guessing a 220# rider who rarely rides two-up would be around the middle shock cam setting.
What's confusing me is that it rides like the shocks have way too much preload. But the bike is bottoming out when it hits a tiny pothole which suggests not enough preload. Hoping to get some wisdom from the smart folks on here. Thanks in advance!
