Yup,,,, Ky2!!!:2thumbs:I use the old hot rod trick to get the oil going. That trick is to fill the oil pump cavity with Vaseline and install the gears. The Vaseline on the gears will cause suction and start the oil flow. I have done that many times over especially with my Turbo V-6 Grand National. You will have to change the oil at about 100 miles which is what I did every time I had to break in a refreshed engine.
Carlos![]()
Being that the pump is enclosed and we don't have the luxury of spinning the pump with an adapter and drill. I agree with you BBChopper the Ole Vaseline or assembly lube will have to do. That is what I would do, just saying. :2thumbs:I always liked Power Priming all the V8’s I built (spin the pump shaft with an adapter and a drill), the Series 53, 72 Detroit’s I built I packed the gears with the old “Vaseline.” Has anyone figured out how to Power Prime a V Twin??? I would think an external pump would be required….
