Gareyh1968
Looking for suggestions for primary oil
What year bike was this again? I use Lucas Primary Oil. Non-Synthetic. It sounds like you need to check your clutch setup. I am going to guess that they didn’t adjust it correctly when they put your clutch pack back together. Pretty easy to do & then you will know for sure where they left the clutch adjustment at. And after you do that if it’s still slipping you are likely going to need to change the clutch pack out. Keep us posted!The reason I asked is because I am new to these bikes. I had work done on it were they replaced the main bearings gaskets and seals in the transmission he Took the clutch out checked everything and put it back in. I was riding it and the clutch started slipping and I barely made it home. So I was thinking they may have put synthetic in the primary. What’s weird is I can put the bike in first gear and still push it and it will roll it’s not easy but it was still roll so I’m wondering if the clutch is gone
It’s a 2007 k9. It was running fine then eventually started slipping till it barely would go. Just did make it up the drivewayWhat year bike was this again? I use Lucas Primary Oil. Non-Synthetic. It sounds like you need to check your clutch setup. I am going to guess that they didn’t adjust it correctly when they put your clutch pack back together. Pretty easy to do & then you will know for sure where they left the clutch adjustment at. And after you do that if it’s still slipping you are likely going to need to change the clutch pack out. Keep us posted!View attachment 89509
That’s what I put it in when I bought itWhat year bike was this again? I use Lucas Primary Oil. Non-Synthetic. It sounds like you need to check your clutch setup. I am going to guess that they didn’t adjust it correctly when they put your clutch pack back together. Pretty easy to do & then you will know for sure where they left the clutch adjustment at. And after you do that if it’s still slipping you are likely going to need to change the clutch pack out. Keep us posted!View attachment 89509
I would for sure drain it & change the fluid if you don’t know what they put in. Could be Redline which would be the worst case scenario. Then check the clutch adjustment. If you haven’t done it before, check out Markymarcs video on YouTube. Good luck Brother!That’s what I put it in when I bought it
Too dusty. Nice bike.
That bike is just freaking sick Awesome! Pretty sure that’s the most rad BigDog I have seen! Great job on keeping that bike looking so great!
Well redline was put in the transmission so I had all the bearings and seals replaced. I drained the primary and put Lucas in it. The 20/50 non syntheticI would for sure drain it & change the fluid if you don’t know what they put in. Could be Redline which would be the worst case scenario. Then check the clutch adjustment. If you haven’t done it before, check out Markymarcs video on YouTube. Good luck Brother!
