Utopiapga
Ok so I probably already know the answer to this question but need reassurance. If you over fill the primary can it cause your gears such as first n second to slip a little and make them not want to come out of hear into neutral? Or while putting on lift did I maybe pinch the clutch cable? I don't think I pinched anything cause all was working fine lost that inner primary belt and lost quite a bit of oil so pulled inspection cover off and added some to spec height. Then buttoned everything up. But now it is hard to get into neutral and in and out of 1st n 2nd??? Does not slip once there thru all gears just acting up in between 1st an 2nd.
Any suggestion please let me know. Just had clutch adjusted and everything so was running freakin great!!
Posted via Mobile Device
