Be careful that the nut on the compensator shaft hasn't come loose. Mine did and was occassionally hitting up against the cover. I would pull the inspection cover at the chain adjuster and see if there is any axial play in the chain out at the engine output shaft area. If you get axial play, could be trouble. When mine came loose it was loose enough it caused the stator cover to touch off agaist the stator coils. You don't want that. It creates a real mess and you'll be replacing the stator coils and cover. Good luck.:2thumbs:
