Primary lube ????
twhiteman42
:confused::confused: I was told by Primo Rivera to put Dextron 2 in my Primary on my 03 chopper cause this is what thier clutches like, does anyone else do this ???? I been running it for a year like this with no problems but so far I am the only one I know of doing this. Doees anyone else do this ????
LDO
The Cleaner
Heard of doing it, never done it myself. I use Revtech Primary fluid.
If it's working for you and you have no adverse effects, 'hold whatcha got!"
BadBrad
2005 Pitbull
Todd,
I went with Dextron III Mercon on my last fluid change. After reading Baker's website, that is what they recommmend for the clutches. No problems with it. :cheers::whoop::cheers:
lee
I'm using Fucktron or something like that (I bought it because of the name!). Stuff for automatic transmissions - works good.
LDO
The Cleaner
Quite the piece of work you are Lee!!:roll::roll:
lee
here it is - the one on the left. OK I got it a little wrong but "Fuchs" must be pronounced as "fucks"!! :D
RCAdd1ct
JAFO
I have a Baker clutch in my ride. The King King to be exact.
I have about 15k miles with ATF in the primary.
Not sure how changing fluids will affect it, but running AFT seems OK to me.
