bigdog1961
how do you remove a stuck primary inspection cover after bolts are out?
should come off, may need to bump it with a rubber hammer,, tape up rubber hammer head or use cloth.. dont suggest hitting cover unprotected.. some times peolple have put silicone inbetween the 2 serfaces, there is a o ring or gasket there suggest replacementhow do you remove a stuck primary inspection cover after bolts are out?
didnt mean hit it just tap, some times it gets stuck,, I'm not a hammer mech.. eather,, not everyone has a pick set,, I do, just tring to use simple tools mose everyone has, & a rubber hammer, not metal, sorry for the confusion....Snap o or any tool dealer sells a set of picks. Use the 90-degree pick to stick in the hole the bolt came out of. Work all 4 holes with this tool if needed. Hook it in and pull easy. Should come off. If you hit it with a hammer you might break the corner off. Don’t recommend the hammer at any time.
No no its ok! I think he knew betterdidnt mean hit it just tap, some times it gets stuck,, I'm not a hammer mech.. eather,, not everyone has a pick set,, I do, just tring to use simple tools mose everyone has, & a rubber hammer, not metal, sorry for the confusion....
You can get the picks cheap. Napa,Advance auto. many other places. normal cost $15.00 for a set of 4. :2thumbs:
