Ok, I've searched without luck. The owners manual states 32 oz of fluid in the primary but somewhere I saw that fluid should cover up to a certain point on the clutch assembly. How far up should it be? Thanks
just pour 1qt in there and you're good to go. Some like to put a little less than that in - overfilling can cause too much drag and sticking clutch plates.
28oz is just right (LSD 2004 softail) i have been trying to fix a leak at the lowest bolt next to the drain, so i've drained it, and replaced it 4 times this week. 28oz puts the level right were is should be each time.
