mcgroom
I am concerned that my primary drain might be stripped.
I had my buddy work on the left side fluid and I did the right. Bullshiting, drinking beer etc.
He has a torque wrench that clicks, mine does not. At some point he stopped and asked if there was something wrong with my wrench? I looked and it appeared that the drain plug was at least 1/4" recessed in the housing. What the fuck.
I backed it back out most of the way and put it back in. I wiped it off and there appeared to be very fine shavings. They may have been there from the fluid change but I doubt it.
Anyways, I started it for a bit to let things work themselves in. No leak at all.
Will the vibration work it back out? If it is not leaking, how do I know for sureif it is stripped? If it is, I assume I will have to replace the inner primary housing. Do I bother or just put a belt drive on it?
I am severly bumming on this one guys. Any advice would be appreciated.
