JeffM
Greetings from the OZ,
I have had a few electrical issues with my 08 K-9, now a few of you cynical bastards out there would find that hard to believe, but for those following my journey will remember the saga related to the L/H handle bar control switch circuit board and the flasher fiasco.
I have now gone to a new circuit board but not connected to the flasher, i even found a "flasher unit" wired into the circuit....................."what the F". Obviously that part of the EHC don't work.
Recently (last Sunday) while out riding it died and would not restart, after deciding it was a flat battery i got a jump start to ride the 40 miles to home, yep you guessed it 50 yards from home up a hill it died again. Got a battery from my fat boy and it fired up straight away.
The following day i started the fault finding and located it to be the Voltage regulator.
Before i changed it i started the bike and checked all functions (except the L/H flasher) and noted that the 'POWER UP CIRCUIT" light on the EHC was flashing................Voltage regulator replacement should fix that i thought, alas no. With the new reg in place and charging away at 13.5 volts the light is still winking at me.
WHAT DOES THAT MEAN??????????????? :bang:
Jeffm
Jeffm
