possible throw-out bearing
jimbo
Have a '08 pitbull and I'm hearing a grinding noise when I pull the clutch leaver. I've pulled primary cover to check for chain tension and to see if clutch hub nut was loose. Everything looked ok but I went ahead and pulled clutch assembly to see if I could find anything. While I had the assembly off I went ahead a removed o-ring behind bearing carrier via. service bulliten posted by toodie. I reinstalled everything and retorqued hub nut after putting loctite on it. Still makes grinding noise when I pull clutch leaver. I'm thinking it could be the throw-out bearing but I not sure. Has anyone had this problem or any ideas? Thanks
jimbo
I'm not sure how to post link but I found post on p.3 in clutch hub nut thread under performance transmission/drive forum. sorry
