Pingel Fuel Valves
NZBigDog
Hi fellow BD owners...
Has anyone rebuilt there Pingel fuel valve??
mine leaks alittle and Pingel have a kit to rebuild but I was thinking I could just pull it apart and replace a couple of O-rings....the pingel kits shows it coming with some new brass bits as well.
Anyone managed to get the valve apart and just replace the O-rings?
francoblay1
The Spaniard
I did pull mine apart to have a look at it and I can´t see why not just replace the o-rings if there is from where it´s leaking. just saying.
S&S recommends the Pingel for their E and G carbs. The only thing I'm concerned about is, Some time manufactures use oddball size O-rings, so you have to buy their kit. I don't know if Pingel did or not, but I've run into that a lot.
john sachs
Golan is hi-flow, I've used them on 176 hp motors with NO problem. I do a ton of S&S carbs, and I consistently recommend, and use Golan petcocks on a lot of them. :2thumbs:
John
pingel fuel valve
On my 3rd Mastiff. I had two Pigels cease on me. Screw that some have a detent, some don"t. Can't tell where they are at half the time. Get a Golan, great quality, forward is on, back is reserve, side is off, all with a detent so there is no fumbling.
I am out of stock on the Golan Inward facing petcock version currently but will have them available in the next 1-2 weeks.
The Forward facing and Rear facing are available
I also have a kit available with the Golan valve in an AN -6 format with the adapter for the S&S E & G carbs and a -6 braided line with AN -6 ends on it.
JeffM
I have the forward facing Golan, great so far.
Original one was a piece of crap, would not turn off, properly and leaked at times.
Go the Golan.
