passenger peg mounts wanted..
show-n-go
If anyone has a set of passenger peg mounts they want to sell let me know. Without them the rear peg hit the pipes. I would also be willing to buy stock rears with mounts, I bought some aftermarket ones in a pinch but I'd prefer it to be stock.
Not sure if there different from model to model but I have an 05 Chopper.
Thanks for any help.
MossBerg590
I have a complete rear passenger set up I wont be using any time soon. Not sure what everything is worth. Let me know what you may want and an offer.
WhiskeyBent
Passenger pegs
If he doesn't jump on this, I might be interested. I have an 04 Ridgeback and am looking for the entire passenger peg setup. If it will fit, of course. Does anyone know if the passenger peg setup is different between LSD and RSD??
Well I was rideing down the street minding my own business and it started looking kinda back fire sounding and stoped running I tryed re starting and it didn't wanna turn over started clicking from the battery Bing to low I tryed to jump it and it felt like it was haveing a hard time turning over
knothead
Battery might be going bad.....maybe charging system isnt working correctly no more ....or a bad connection somewhere in the charging system, battery connection , etc....low voltage will make it backfire for several miles and then die...test ur battery first and connections and then work ur way back to the charging system...most likely ur battery is taking a shit
  • Like
Reactions: LHS
Also just an FYI, when your jump starting these bikes, make sure the vehicle but you're jumping from is not running. You'll pop your EHC if it is.
We
Agm sealed battery I got from auto zone
We're going to ask a bunch of dumb questions because we're not standing over the bike. So I'll try to ask a bunch at one time to get you going faster.
Just because a battery is new and fits in that bike, doesn't mean it will work.
What is the cca rating on that battery? Did you clean the cable ends good when you replaced it. Check the other end of the ground cable,where it mounts on the starter bolt. Make sure it is tight and not pulling out of the end. When you push the start button, are the compression releases working?
Wait here is a question I changed the position of the battery and added a new cable to the starter from the battery I wonder if because the cable is longer if it could have a harder time starting the bike im also not Shure if the staiter is. Charging while I'm rideing I added a new voltage regulator and I sware I'll charge ride around town. Stop a few spots and by the third or fourth time its dead it sucks
The plug on the front of the engine that the VR plugs into. Set your Volt meter to AC, and put it in the two holes. It should read 20 to 25 volts AC
