I need one also, mine is shot. Rivets don't help anymore!! I've been watching his sales but he hasn't listed any rotors like my wheels.Need the hole rotor for the rear of mine, matching my wheels.
Email is shovelheadkicker1@yahoo.comDoes anyone know how to get to Shovelheadkickers , things on e-bay. I don't even know if he goes by that on e-bay any more or not. Just tring to find more used parts for 05 chopper. Need the hole rotor for the rear of mine, matching my wheels.
'I'd try the rivets Ray but they are about $12. apiece I can almost buy some rotors for that. If you find any anywhere Ray and they are more than one let me know and I will do the same.
Maybe I missing something here, but why were, or are, you guys "Riveting" your rotors together, because of rotor rattle?
dead![]()
I know that Mr. Smarty pants.floating
two piece
like your hair line
:roll::roll::roll::roll::roll::roll::roll:two piece
like your hair line
Thanks Oscar! Ha, Ha, Ha....:zzdisappointed::roll::roll::roll::roll::roll::roll::roll:
Gotta' admit - That was funny!!!!!!:2thumbs:
Good then, can I use your "rug" to wipe my feet off on?Time will come?!?!?
I'm already there!:lol::lol::lol::lol::lol:
I meant rotor pins. I've replaced them twice and with new pins they still exceed minimum standards (rotational travel). Very loose so need a new rotor but what do you expect for almost 70,000 miles!But why install "Rivets"! They come with fasteners.
Unless they're referring to the fasteners "Rotor Pins" as "Rivets".
You just need to measure the thickness of your present "spring tension washers" and get some thicker ones. :2thumbs:I meant rotor pins. I've replaced them twice and with new pins they still exceed minimum standards (rotational travel). Very loose so need a new rotor but what do you expect for almost 70,000 miles!![]()
Bending spring steel is sometimes very hard or near impossible, but it's always worth a try.How can the spring tension washers take the slack out of the pins.I can see where the washers would tighten the pin up but would not make the pin thicker to take the slack out. I tried rebending the curve on the washers like you said but it did not work. But I will check at Lowe's I'll try almost anything once.
