Painting heads and jugs
bigd1960
Took my engine apart and thinking about getting jugs and heads painted. My local powder coating shop tells me they can do it but I'm afraid that it will retain too much heat. What other solutions do I have?
francoblay1
The Spaniard
I am sure someone else will chime in shortly... but, If I am not mistaken, black powder coating does the reverse... it does get rid of heat!
Little-Boo
I don't think paint is going to hold up to good, but to each is own.
I had mine Powder coated several years ago and have not had any problems with the bike heating up. I had the powder coating shop send them to "Diamond Cut" and had them do the show diamond cut. They look good to me :2thumbs:
Carlos :whoop:
bigd1960
Thanks. Was just worried about the possible heat factor with powder coating. Maybe I think too much!
Have a good one!
When I got my bike, the last guy had painted the jugs, and they were looking like crap, So I repainted them last year when I painted the bike, and once again there looking like crap. And I used some high $ paint. If you powder coat them and then have them diamond cut, I think that would cool as hell.
Splitlog
Dont paint...Powdercoat only.
A buddy of mine had his powdercoated and then diamon cut..its been over 5 years
and they look great.
Paint would look like crap in a year
just my .2
BBChopper
Supports 2 Disabled Vets
Painted mine a while back with ceramic header paint, lasted ok but it was a temp. Mine will be back from powder and machining next week!:2thumbs:
bigd1960
Thanks
Appreciate the feed back. Turned out a good polishing compound and hours of elbow grease worked wonders.
RCAdd1ct
JAFO
Ceramicoat will last longer than powdercoat. Under higher heat powdercoat will grey.....like 400 degrees. The heat shields on my twin cam turned grey from glossy black. They also softened to where they started getting tool marks.
Eventually you will have to polish glossy powdercoat. Less so with Ceramicoat.
I did my latest exhaust with jethot Ceramicoat and they are perfect. Not cheap, but perfect.
TapioK
Well, as far as I know ceramic coating is often used to prevent gasses cooling in exhaust systems, or keeping the heat out, say in space shuttle. i.e. its great insulator.
A 5 mil steel sheet with a 5 mil calcium silicate coating has about 1/90th the thermal conductivity of a plain 5 mil steel sheet.
So if you are worried about jugs ever overheating I would not ceramicoat them, though the coat is really thin, but still…
Tapio
RCAdd1ct
JAFO
Tapio
True, but I think HD's black is a form of Ceramicoat.
TapioK
Yeah, in these thicknesses (?) the difference in cooling is most likely theoretical... Coating may (again in theory) spread the heat more evenly... Not bad.
Tapio
RCAdd1ct
JAFO
If I ever take mine apart I will get the S&S 124 kit and discuss color options with them. They sell black and warranty them so I am sure there are some options....even if it is black.
Then diamond cut them like my TC 124.
