Oxygen Sensor
Hi,
Does anyone know if there are shorter oxygen sensors available somewhere? I welded the oxygen bungs in my pipes and apparently the V&H pipes fit a little tighter to the motor as the rear sensor hits. The angle is right, however I should have welded it in at a different angle to help give it clearance. These sensors are quite a bit longer than a Harley sensor. The easy fix would be to replace the sensor.
Thanks, Vince
pknowles
RETIRED
Two different sizes.12 and 18 mm. Use a torch and heat the pipe/bend the Bung up/down enough to fit the sensor.remove sensor before heating.
