One of the Primo nut clutch plate nuts won't come loose
My primary drive sprocket on the clutch basket seems to a separated from the clutch basket. Can't get one of the 4 clutch plate nuts to come off it just spins. Anybody ever had this problem? Looking for any suggestions on how to get the damn thing off
Yeah, just did one not ro long ago. Had to use a die grinder and cut the head off. Note: it is the long nuts you will need to replace it. The ones on the Primo site are short. I ended up having to make a nut.
There is a nut on the back side that came loose. You might try tightening that nut and see if the back one will tighten back up enough to get the outer one off.
