This is with cold oil..... try again with FULLY Warmed up engine!That's very incorrect! Watch this video!
http://youtu.be/f_kn1JEFApQ
I'm with you on this one because my 107 has the same pressure which is not normal. I tried 2 different gauges and still the same. The only thing I can think of is BD got some hi pressure oil pumps to fool with or at a discount and put them in a few bikes. I'm at 50 lbs running hot and 25 idle. It could also be the oil line used to the gauge but I doubt it.I'm telling you after a 30 min or 4 hr ride I'm still at 20-25 psi on my gauge
that is probably a better place than after the twin coolers as it is on mine.On my HD I installed it between the motor and the Oil filter so I'm getting oil that has just come out of the motor heading to the filter then the cooler.
Get a K&P filter :up:Thanks for the feedback! Got another question! With low pressures on the Evo style engines, when choosing an oil filter, which would be better on the bypass psi? 8 or 17!? Or does it matter?
I do not know what the bypass psi should be but make sure that you get hi flow oil filter! Very important. Oil filters for twin cam are NOT hi flow and are to restrictive.Thanks for the feedback! Got another question! With low pressures on the Evo style engines, when choosing an oil filter, which would be better on the bypass psi? 8 or 17!? Or does it matter?
