Oil line for '05 Chopper
ChopperJeff
Does anyone know the length of the oil line needed for an '05 Chopper, coming out from the oil tank? I checked the service manual and didn't see anything.
My bike has a very slow oil leak, and in looking underneath it, I found that the oil line coming out of the oil tank was rubbing against the shock, and had the braiding rubbed off. I managed to move the line over a bit so as to get some space between it and the shock, but then didn't notice any oil at that exact spot on the line.
Then checked farther up the same line towards the engine, and about 5 inches up noticed another spot with the braiding worn off. I suspect that's where the oil is coming from, but will look again to be sure.
Bottom line though is that I need a new oil line.
That said, I noticed this stuff called PTFE Braided Stainless Steel Oil Gas Line on eBay for $3.49/foot. Will this stuff be OK?
The link is:
PTFE Braided Stainless Steel Oil Gas Line - -6AN : eBay Motors (item 110484192612 end time May-20-10 14:05:17 PDT)
MARV
there's 3 coming out of the tank
tank to filter is 27
tank to oil pump is 12.75
tank to the case above pump is 19.25
from filter to pump is 9.75
measured end to end
all have female ends
got 3 out of 4 on ebay for cheap but havent found the 27 yet
