Oil line fittings
Larry T
I broke the fitting where the line goes into the motor I got it out but I'm having trouble figuring out what size the connection is they sent me a 1/8 6an but the 1/8 is to small and its straight not tampered
Sent from my SM-G991U using Tapatalk
Mickmorris
Well Known Member
I think that’s a 3/8 or 13/32 threaded opening
Rottweiler
Who is they? I'm sure someone on here knows what size off the top of the heads. Not me.
I'm sure if this is who sent it they will fix it quickly. Also you should be able to get it from.
https://www.bigdogpartskingpin.com/ I would call on of these places.
Mickmorris
Well Known Member
Yes pairs to the oil line fine
Yeah give Eric a call for sure to start. He will get that taken care of for sure. Post a picture of the new threaded end at the opening in the crankcase. Sometimes seeing the problem helps to troubleshoot it.
