camaro4516
Got my oil cooler in can someone walk me through how the hoses go?? Or show me some pics of how it goes?? Thanks...David
You can check the tech. how to section.
remember,search first, ask later.
Good point, I dont recall one though. But could be becouse I already had mine in.:2thumbs:You can check the tech. how to section.
Yup I came up bust!! Hey Gas!!!!I did a search and came up empty. Do you know where I can find it??![]()
I'll get you the info tonight or tomorrow Camaro when I get home. I have the 03 which should plumb up just like yours. The kits comes with new lines right? I'll tell you which one goes where when I take a look at my bike tonight.
It's pretty simple camaro. You go from your outlet on the oil filter (this will be the return line to the oil tank or the longer of the two lines) to the first oil cooler inlet, then the outlet of the first oil cooler to the inlet of the second cooler then the outlet of the second cooler to the oil tank return line you started with. You can patch the last return line with a fitting or get a new piece of oil line (longer) and re-route it.It came with new lines and what I did was buy 2 coolers and Im going to loop them together. Any help you can give me would be great. Thanks...C
Just called you David ... those were supposed to have instructions included.
