Point08 Member Oct 25, 2008 #1 I have the T&P set-up and suspect this is the cause of the oil buring due to the front plug is oil fouled. Any suggestions? Is is best to go with the S&S set-up? Whats the cost?
Raywood The Pirate Staff member Calendar Participant Troop Supporter Oct 25, 2008 #2 Lot more than just this here is you would conduct a search. http://www.bigdogbiker.com/forums/technical/8093-rocker-boxes.html http://www.bigdogbiker.com/forums/t...per-valve-guides-oval-d-not-covered-help.html http://www.bigdogbiker.com/forums/general/3193-anyone-had-tp-rocker-boxes-changed-out-s-s.html http://www.bigdogbiker.com/forums/technical/7089-tp-rocker-box-s-s-billet.html http://www.bigdogbiker.com/forums/how/4603-how-replacing-your-rocker-boxes-gaskets.html http://www.bigdogbiker.com/forums/technical/3987-05-tp-rockers.html
lee Well-Known Member Oct 25, 2008 #3 my S&S rocker boxes turned up today. I paid $275 and put the link to the seller on ebay on here a couple of weeks ago. You should be able to find it.
ChuckRB05 Active Member Oct 27, 2008 #4 re Might want to due a search on valve guide issues. Those are the same symtoms I had on my 05.
G General_Mayhem Member Oct 30, 2008 #5 See my post with bad valve guide pictures: http://www.bigdogbiker.com/forums/performance/8527-headwork-done-rolling-down-road-tp-boxes-replaced-05-chopper.html
