Oil and fuel leaking
Bulldog02
Finally got the bike started...Now its leaking a lot of oil and gas is just coming out the overflow tube. The oil is coming from the line that goes to the air filter. Any thoughts?
Your float is likely stuck in the carburetor. Pull the carb and rebuild it.
You may need to change the oil or it might be overfilled
Bulldog02
Okay...started looking at the carb and the two nipple covers were on however the tops of them were gone..replaced them and no more gas leak. Only thing now is the engine seems to stumble when i give it gas...found a S&S carb tuning guide on the forum so Im going to try and fix that problem...other then that everything seems to be running great.
