No speedo or odometer
migai082681
Installed a wire plus kit on my 2008 ridgeback everything work for about two weeks one day out for a rider and my speed gos out then comes back on then dose out again . Have checked all wires for a lose connection but all look good. Cleaned my speed sensor but still nothing. I could do with out knowing how fast im going but would like to know how many more miles till empty. Dose any one know how to turn on the hazards with the wire plus. Thanks any help would be good.
BigDogBro1
Made in the USA
You need to electrically check the speedo head power and signal connections to start with. Then work your way back to the Wire+ and speed sensor at output trans pulley.
alphadog
Did you check the connections on the backbone under the gas tank? My speedo acted the same. The jsp connector had a broken tab.
ro360s
Same issue but it was the red power wire was broken off at the speedo. Soldered her up and now good to go. Good luck
migai082681
If it is the connection under the tank out the rpm still work because mine works the only thing i lost is the speed and odometer
