I have an 03 pitbull and when I first start up It is pushing 20lbs of pressure, But as the motor heats up it will drop to 10lbs and eventually drop to 0lbs. I can bring the pressure up if I add some rpm's but that is about 1500 to 2000. no noise down below. I have changed the oil- straight 50 wt and flushed the lines but I get the same thing. I swapped gauges as well. A friend told me he thought there might have been an issue with the pumps at one time but wasnt sure. I have also noticed a noise from behind the cam cover that comes and goes. sounds like a spring flinging around or something to that effect. Anyone know why the pressure would drop to ZERO?
